I'm been having a really hard time with my EGR system on my '94 grand am gt. it has a 3.1
I am getting the "egr XX solenoid failure". generally its code 75, but it has been 76 or 77.
I replaced the valve, obviously, that did nothing. After talking to a few mechanics, I pulled the TB and cleaned out the totally plugged EGR passage in the upper intake. I said "yay" because I thought it was fixed. (in the mean-time, I replaced the plugs and wires which fixed a bad driveablity problem). After driving it, the light will still come on when I am coasting down from 65mph or so, and stay on (btw, I pulled the negative terminal for a long time to clear the ECM). Today, I pulled the ECM, and checked the 3 EGR wires in the harness. No shorts, not ground, and I shorted each pin to one another to make sure I had good continuity to the plugs.
then I checked terminal D (the positive terminal that goes to the ERLS fuse in the fuse block). The only thing I could come up with is that I am reading 20 ohms of resistance from that to ground (with the fuse removed). Is this normal? I tried to track it down but lost the pink wire in the main harness over the tranny. ALLDATA says it goes to "10-WAY IP CONNECTER" then to the fuse block.. couldn't find any of that.
Any suggestions? I wanna shoot this thing many times and roll it down over the hill.
The only thing I can think of is that the ECM is FOOBARed or that the B+ wire going to the fuse block is grounded or something.
Also, if any one has a GA GT (94-95) can you burn any serious tire, or just chirp them from a start?
