3,4L LA1 engine in a s10 1991
  • 3,4L LA1 engine in a s10 1991
    can i get a LA1 engine in my s10 or only the older 3,4L engine which built until 95? i have a t5 transmission!
    i hope you understand me,because i live in germany!
    Nope LA1 is a FWD motor. It is a no go, as far as drop ins are concerned.
      Where in Germany are you. I am in Germany too. Sorry to whore the thread...
        Pirmasens south from Kaiserslautern (K´town)
        what engine can i get in my s10?
        the 3,4L from 95 out of a camaro?
          Yes 1993 to 1995. Or the GM crate motor.
          Read this http://members.shaw.ca/betterthanyou...ine%20swap.htm
            what 3,4L engine have you in your sonoma?
              A 1995 Camaro motor.
                and how fast is your s10 now!
                can i use a chip or damage that my 3,4L engine?
                what can i tune on this engine? because i want over 200HP!
                does the engine hold out in the long term?
                are the headers for 2,8L and 3,4L engines alike?
                i write a shit english!
                  The 3.4L from the Camaro is just like the 2.8L in the S-10. Only it has a bigger bore and stroke.
                  I am probabally making close to 200HP and it is ALOT faster than it was before.
                    Two hundred horsepower would be the practical limit for a normally aspirated[carb/ f.i.] stock longblock 3.4. You would be mainly be upgrading fuel induction,cam and exhaust and then ignition curve.I saw one that was said to make 200 hp with a compcams 268 and weber carbs. P.S. Your English is fine!
                      200HP and a 3,4L engine are very much the most people drive with 1,6L engines!
                      for 1L gas you must pay 1,20$!
                      that is very expensive in germany!
                        can i the header for the2,8L engine use for the 3,4L engine?
                        do you understand?
                          Can you use headers from a 2.8 engine on a 3.4 engine? Yes,if they both engines are from a rwd .
                            can i reach 200HP with header,chip and a crane cam from 1500-4500RPM?
                            need i more things to get 200HP or more?
                            can i swap my s10 with all parts from the 3,4L camaro or need i parts from the 2,8L engine?i want drive the 3,4L engine without 2,8L parts!
