I Thought u were.. I was putting some info together.. I guess i was wrong..
My Mistake!! Sorry
Robert
--------------------------------------------------- 96 Grand Prix SE 3100 202,000 miles
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Now's a good time to replace the uimg while you're in there replacing the O-ring. It's not that hard to do, should take you an hour if you're good with the hand tools.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
I replaced the distrubutor oring. To do so i had to remove the fuel rail. Now Im leaking gas. In short trips i can open the hood and see puddles of gas on the LIM by the injectors. I took it all apart again and replaced the lower injector orings and still leaking... Now what? I dont understand how its leaking fuel. The rail is tight..
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
mine done the same thing, even tho there clip on, its possible that its the upper o ring. when i first got my hybrid running i had to change EVERY upper o-ring before it would stop leaking. and also, make sure they have a bit of oil on them. and seated properly
Even clipped they can be moved and if they are moved a little bit (taking the rail off the LIM) then you now have the o-ring at a different angle and the depression from being at a certain angle now is moved, so it can leak.
