i recently bought two s10s the one doesn't run. when you go to start it it start to pop back through the tb(throttle body) any in put on what i should try to do to fixs the probelm would be great thanks ahead of time
2.8 s10 troble shooting
The distributor is 180* out of timing.
This is what it needs to look like
REMEMBER all settings must be done with #1 cylinder on TDC COMPRESSION stroke.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
That is the most probabal cause. Otherwise, it could be a bent valve or perhaps a cracked cam or someoen could have tried to install a cam or timing chain and didn't time the cam correctly to the crank. But, most likely the wires are on backwards or the distributor is turned.
-DaveIf I seem Crazy it is because, I am insane. No lie. Ask my psychiatrist. But, i have good intentions. sometimes.
