1999 Lumina, 3.1L engine.
I got a mystery coolant leak that started today, but watery residue on bottom of chassis seems oily too.
I know it's the coolant because it was low and there was a puddle on ground. Oil seems ok--not milky or anything.
I put a new metal LIM in it a few months ago. I checked around the interface area, don't see anything unusual.
Checked usual suspects: hoses, water pump, etc. --just don't see anything in those areas.
It seem to be leaking in the area under the Harmonic balancer area and into the strange oval shaped transmission/engine mount thing. It's leaking outta the holes in the bottom of mount and onto the ground. I can't see very well in that area (too much stuff in the way). Are there any freeze plugs or anything else around there prone to leaking? It seems to be a slow leak, I'm trying to get it to leak again but it won't do it right off.
Thanks for input...
Thanks for input...
