Can someone direct me to a site or link with detailed (step by step) procedure for timing cover on a 96 Monte w/3100 ? I'm preparing for a timing cover gasket(s) replacement and need to know what tools I will need and tips on what kind of surprises to expect.
Does the oil pan have to come off ?
Do I have to drop the cross member or lift the engine (partially) out of the
engine bay ?
The torx bolts holding the timimg cover to the block,are they really a "pita" to remove and are they prone to snapping off ? What can be done to prevent breaking them ?
Any special tools I'm gonna be needing to borrow such as a puller for the lower pulley (harmonic balancer) or will a steering wheel puller do the trick ?
Maybe a six foot pipe on the end of a ratchet to loosen the bolts like the head bolts required to be removed.
I just finished replacing the rear head gasket and rear exhaust manifold only to drive home and have the Monte puke dexcool all over the driveway AGAIN !
Everything seemed fine when we finished that job including bleeding the cooling system,road testing to normal operating temp then letting it cool down and rechecking dexcool level.
Any help would be greatly appreciated. -Paul-
engine bay ?
