2.8 alu head replacement
  • 2.8 alu head replacement
    hey there, quick question
    will aluminum heads from a 1988 2.8 corsica fit up to a 3.1 from a 1992 lumina van? and will the intake from the throttle body lumina cause any clearance issues with the MPFI corsy heads?
    thanx
    Speak softly and carry a big six.
    No. The Lumina van used Iron heads and TBI. None of the aluminum heads even come close to fitting the TBI intake. Also the pistons in a RWD block would increase the compression beyond 11:1 and you would need careful tuning and premium gas in order to keep them.
      so the only possibility would be a mpfi conversion then?
        Yes. But if your taking that project on just forget it and get a 3X00 top end and use that. More power for nearly the same price since 3400's are a dime a dozen in the junkyard now.
          thanx
            what about the crank from a 3.1 corsy in the 3.1 lumina van?
              same, whats the point here?
              2012 Chevy Sonic Turbo 6spd
                ....get a 3X00 top end and use that. More power for nearly the same price since 3400's are a dime a dozen in the junkyard now.
                Top End - Everything above block?
                Fat chance 3.8 motor iron heads work on 2.8/3.1 motors?
                  3.8 are 90* motors not 60*.
