So, on the Trooper 3.4L SFI conversion project: I got it running and driving, however it was running super rich. I had an injector (#3) that was leaking terribly. I have a spare set of injectors from a bundle of parts I bought (from a similar 93-95 SFI 3.4L), unknown condition, but I was hoping they at least wouldn't be AS bad. The part number stamped on them was different than my originals, so I opted to switch all the injectors to keep everything the same. Stupidly, I didn't make note of the number before I installed them. Anyway, I got everything is back together and it fired right up. Ran for a couple seconds, then died. Since then, I get NOTHING. I have spark, I have fuel pressure, I have 12v to the injectors (no noid light to test though). The spare injectors are the same impedance as the original ones.
I can only assume that I roasted the ECU somehow. I did blow a fuse on my custom wiring harness at some point (which is unlabeled of course). I never disconnected the battery while I was working on it; again, kind of stupid. The fuse (10A) has been replaced and it holds.
I have another ECU from an automatic equipped vehicle (Trooper is a 5-sp). I tried swapping that in, still no fire. My harness does have a VATS bypass built in, any idea if that is specific to the ECU? I'll call the place that made it Monday morning to find out for sure.
Any thoughts?
Any thoughts?
