hey whats the best way i don't have that tool. i have in the past used thin plastic but idk if it will work now
stupid car lol
Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
still no go but if i pull the pcm fuse and crank for a bit then put the fuse back in she kicks! im thinkin its an injector leak or somthing!
they are wet do they need to be replaced? or can i dry'em?
there dry but man this crank till she dies then charge for an hour is killing me lol
think i found a broke vac line under the dash next to the pcm. also man my floor is wet so it's a pain lol. i put some seafoam in the gas tank to try to take the water out of the gas
yes thay are black! should i sand them?. Is there an easy way to check for compreshion(sp?)? cranks normal though
New odd problem the temp gauge is going up!. I find this odd cuz there is no coolant in the motor yet 'lol'
where is the sensor located?
btw i put sea foam in the gas and my needle dropped! I'd say the water is gone, 'lol'
i have many spare injectors and another fuel rail. So I'm gonna try and change them all out because the car is getting way to much gas by the look of things. it is now backfire through the exhaust too
