Hey i have 01 3100 topend, can someone tell me the stud is 47 lbs? and the roller rocker is 18 lb? It is turbo so i want to make sure.... any help apreciated, btw i dont have a 3100 manual...
rocker arm and stud Torque specs
dont remember when they changed the stud size but this is from my 99
Rocker arm bolt 14 N.m (124 lb. in.) plus 30°sigpic
99 Grand Am GT
sounds right^^^94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
i got that from my alldata online so it better be right.sigpic
99 Grand Am GT
I torqued my 97 lumina's to 25 ft/lbs. then drove it for another two years w/o problems--even after I found out that at 35 ft/lbs the threads in the heads are at the max!. yep! heli-coiled it!i didn't have a way to measure degrees haha oh well!
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
damn that reminds me i need an inch pounds torque wrench and a torque wrench that goes higher than 75 ft lbs. at the time that was higher than anything i was doing.sigpic
99 Grand Am GT
i you can't torque the rockers to 124 ft/lbs. the threads will strip out waaayy before that. damn aluminum.Andy
Hrmmm I always just made them tight... without a torque wrench... never had a problem with mine.
Impact gun FTW!
I forget what I put mine at but it's what chiltons said and it's just torq and this it, no extra turning. Done it 3 times and no problems.sigpicNew 2010 project (click image)
