My STE just started doing this a few days ago, but because of the weather I have not had a chance to look into this.
I was on my way home from my parents house. I was going about 45-50 MPH in 4th gear when the engine started bogging down, missing, hesitating, and backfiring. I was holding the pedal steady and it was almost bucking.
It finally stalled, so I pulled over to restart it (PNP switch is not adjusted properly, so I have to put it in park to restart it). It started up fine, and I took off, and it was normal, but once it hit 4th gear, it started doing it again. When I turned onto my road, it stalled again, so I restarted it, and once again, it took off normal.
As I went around the curve, I was doing like 30 MPH in 3rd gear, and it started doing it again. It lasted about a half mile ot the house and died as I was pulling into the driveway.
Today, I finally did some checking. Obvious stuff seems fine. The car started up fine, and nothing arcing, and no funny noises.
Once the car warmed up, the exhaust note changed, and when I went to the engine, it started doing the hesitation, misfire, backfire when I would mess with the throttle.
This is something TOTALLY NEW. It has never done this before, and I have not made any changes to anything in the car within the past MONTH.
Here is a vid of the EXHAUST SIDE. 27 seconds into it, you hear the exhaust note change. It almost sounds like it is just going into closed loop, but once it did that, it didn't go back to normal, and that is when the engine started doing weird stuff. The engine was fine until the exhaust note changed.
This is the engine vid. When I play with the throttle, you can hear it start doing weird things. It even backfires. In the end, I go to goose it, and it just stalls out.
If I let the car cool down, it starts up again fine, but once it starts warming up, and goes into closed loop, it starts doing this.
On top of all of this, the engine still has that minor SURGING when coming to a stop. I am sure they are related, but I can't find the connection.
Any ideas?
Any ideas?
