Hi everyone.
I am trying to get my car to pass air care
. I pass everything expet for nox. everything else is below average.
I have put a new cat on before i tested it so i know that is working ok.
when i first tested it the nox was at 1900+ ppm.
I put in a extra egr i had around and also checked my plugs. on plug was bad. This time around the nox was the high 1400. so it did improve.
A little history about this car. I Drove the car off a 10 foot bank. that broke a motor mount and bent the control arm. after this it didn't really run good. a few months later it would not stay running, i change the ignition moudue, the temputer sensor because the wire was melted and shorted out, and then i changed the ecm and prom. that finally fixed the issue with it stalling. Also had new plugs at that time.
Then a few months later the heater core blew and i had to replace that. Now sometime i hear a gurgling sound coming from the heater core area. but that just started recently.
Sorry for the long post but if anyone can help me that would be appreciated
