First off, what a PITA! I'm doing the gasket change with the engine in the car yet and it sucks. Would have been a whole lot easier to simply pull the engine and do it on a stand.
Anyway, I have a couple questions. I already have the upper intake off and some other misc. stuff.
1) Looking at the bolts from the UIM, I'm assuming that I will need to put some type of thread sealant on these when I put it back together. What is everyones favorite kind to use?
2) My manual says I must relieve the fuel pressure. How can I do this? Keep in mind that the UIM is already off so unhooking the fuel pump and running the engine will not work.
3) There is a metal tube coming out of the top of the water pump. It has a rubber hose on on side going under the UIM. Coming off of the other side, the metal tube continues and follows the head and then follows the exhaust manifold to the back of the engine. Anyone know what this is and how I can remove it? It already made the process painful because it had a bracket that was bolted to the TB and had almost no give to even remove the TB. I suppose I could take a picture if need be.
Again, thanks in advance. I hope this project is done before next Friday!
