91 beretta 3.1 auto
I have a laptop with ALDL cables and tunerpro so I can datalog it
the MAP is showing 55kpa at idle, so its dumping 2x as much fuel it needs and running like crap.
heres what I've done sofar:
looked at all the vacuum lines - no cracks
ohm'd the injectors, all were between 12-12.2
cleaned the plenum and installed new gasket
cleaned the TB and installed new gasket
completely disassembled EGR/cleaned new gasket
changed the PCV valve
replaced the O2 sensor (old one broke in 3 pieces)
tried a different IAC (IAC counts seem lower now)
tried the ECM from my Z24
tried the ECM and memcal from Z24
replaced the map connector
tried a different vacuum source for the MAP
plugged the EVAP and cruise, hvac, vacuum ball lines
tried different MAP of course
and ya I disconnected the battery...
