Originally posted by IsaacHayes
View Post
Got almost everything done... Sadly, I have to redo the FPR - must have not gotten an o-ring right - it's leaking fuel onto the LIM
___________
Not sure if I should start another post or not...
the check engine light came on, showing code: 44
I am pretty sure that means low voltage on the O2 sensor... The thing is, it is a brand-new O2 sensor...
Could this be related to the engine still not running right because of the fuel?
I gather that if the air/fuel mixture is too far off (running lean because of not enough fuel???) it will throw a code 44.
FYI - the ECM is from a 93 Buick Regal (a "16149396" ECM) with the 3.1 MPFI and a 4T60-E
Thanks!
