a gm dis module will run an engine without any input from the pcm. if you remove the bypass wire (supplies 5 volts to signal the icm to use the pcm timing inputs when the engine is running) the engine will still run, itll just be at fixed timing. the pcm doesnt controll timing till after the engine is running, the first couple second is all the icm.
if the pcm is getting a tach signal and injecting fuel, its getting the tach signal from the module, meaning the cps is good.
im not sure what to say.
