Just finished head gasket and LIM repair job. The motor runs just fine. The only thing different about it now is it cranks kind of slow, like the starter is having extra resistance turning over the motor. Not dead battery slow, but it kind of has that same sound to it. It still always starts, but before the repair the motor used to crank effortlessly for startup. What could have changed and how to fix? Only think I can think of is that maybe the rockers are too tight? But I used a brand new Sears torque wrench to set them, so I doubt that is the problem. Manual said 124 in-lb for my 1998 Monte Carlo 3100.
I just torqued them all down with the motor at the same point of rotation. I did this because the manual didn't say anything about needing to set the lifters on the base circle of the cam before tightening, which is a procedure I have seen done on other motors. Did I do wrong??
