Ive been dealing with all sorts of problems with my Fiero after swapping in a 3.1 and ecm from a 1990 Lumina. My Fiero has a 5 speed, so I had the computer tuned for a manual tranny. For almost 6 months, the car ran really rough and lopey. It turns out the IAC was stuck or something... because after I removed it, cleaned it, and reinstalled it, it started to run normal. I also had a wandering idle issue to deal with, which turned out to be my tps sensor. I replaced the TPS with another used unit, and the wandering idle was gone.
The only problem I have now is a slight hesitation. While the car is sitting and idling, I can give it a quick, light tap of the throttle, and the engine will suck air, start to die, then rev up. It happens fairly quick, but is very noticeable. It also happens during normal driving, inbetween shifts. It will almost kill the car shifting into 2nd gear. The thing I dont understand, is that the car runs fine when you give it a lot of gas.... either sitting in neutral or while driving. This hesitation only happens at light taps of the throttle and during normal driving.
I found another used TPS and tried it out..... nothing but a wandering idle resulted. Ive also switched 4 different MAP sensors, none which helped the problem. I do have a scanner however, and compared MAP readings under various conditions with another buddies car, and everything looked normal. Something that made me wonder though, is that my car is throwing a code, which says the MAP voltage is too high. Ive also tried other IAC's, to no avail. I cant think of anything else that could be wrong to cause this hesitation, but I would love to get it figured out so the car can be driveable! Thanks for any insights
