For starters the engine is a late model year 03 3400 that came out of an 04 Grand Am. The engine has 38k miles on it, and I've only owned the engine for less than 3 weeks - during which time its sat on an engine stand catching cleanings, parts, and awaiting install.
Anyways, I went to install my crank scraper earlier this evening and it installed without a hitch. On the test rotations there was no noise from the engine what so ever. But, after I got the main cap bolts torqued back down to 37 ft lbs + 77 degrees, I turned the engine over and it was making noise from the timing cover. In the midst of getting pissed I figured it was the timing chain, so I pulled the cover and sure enough the timing chain now has some slight slack and it hops enough to make a fairly loud noise 2-3 times per revolution of the engine.
I'm pretty baffled and wondering what the consensus is here on what went wrong... It's a low mile engine, clean as a whistle inside, and I don't think that my installing of the scraper would give any ill effects like this. I've got a lot of years turning wrenches and what not so I don't think I noobed anything to death... Any input at all from anyone with any ideas is going to be super helpful because I'm feeling pretty upset right now.
