Before we go and replace the 24x sensor (I agree don't get autozone electronics), try replacing the plugs.
1) Since you gapped them normally you could have damaged the coating.
2) I've read from spark plug manufacturers that even with a platinum plug 30k is when they say to replace.
3) If they are worn/damaged that would explain the red color and missfires at cold temps.
Go pick up 6 R44LTSM6 if you don't want to spend a lot of money, or 6 of the 41-101 iridiums (don't gap em!) and you should run a lot better.
Your spark plugs are questionable and that directly relates to miss-fires/etc.
