90 Olds Cutlass Supreme SL - Help pinpoint problem
  • 90 Olds Cutlass Supreme SL - Help pinpoint problem
    ok so i have a 90 olds cutlass supreme SL with 3.1L V6 and here are the symptoms.
    - Car hessitates for a second when you step on the gas
    - Car dies in gear when stopped for more then 30 sec after driving
    My tests:
    1. testing the wires in the front of the engine. and they tested in spec
    2. pulled the plugs in front and they were normal and were still in gap speck
    3. Put a timing light on each wire and 1 and 3 mis-spark some and 5 mis-sparks seldom. 2,4,6 are perfect
    ok the coil is like this [1 | 4] [6 | 3] [2 | 5]
    Ok so can you give me any ideas?
    Hypothesis:
    is something is wrong with the plug wires going to the back of the engine? like maybe leaking spark somewhere? they do look like origional wires....hrmmm
    have u tested the coil packs... sounds like u might have a week pack or to
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
      Yea if you are seeing a miss then there is an obvious ignition problem.
      The coild and ignition module could both be to blame.
        Possibly the last owner never changed the rear plugs? 1,3, and 5 is in the back.
        Brian
        3400 SFI V6, 4T60e
          yea, but would this cause the timing light to not light up correctly?
          AND to everyone: how can i test the coil paks and what are the specs?
            no other input?
              The only test I have involves using a GM scanner. The only other logical way to do it, is replace them with ones known to work before you go buy new ones. All GM coil packs are the same to maybe you could borrow some off people you know.
