I am a newby who needs to pull the 3.1L engine out of my daughters 1998 Olds Achieva. I have the Chilton and Mitchell manuals for this car, and they both say that the engine and trans are removed as a unit thru the bottom of the car.
I really don't have the facilities to raise the car off the engine/trans like the manuals say and am hoping that the engine can be unbolted from the trans and lifted out of the engine compartment.
I see where there is an "impossible to get to" engine to trans bolt (the bottom one on the firewall side) that may be the reason the engine & trans need to be removed together.
Here's my question (finally!).
- If I remove the upper end of the engine (intake manifolds, heads, exhaust manifolds) so I have access to all the engine to trans bolts, is there room at the front of the engine to side it forward enough for the flex-plate to clear the trans?
If the answer is no, and I need to do what the manuals say, I would appreciate any tips you could give me. I do not know how I could lift the car high enough to clear the engine/trans to remove it thru the bottom.
Thank You
Steve
Thank You
Steve
