I am having problems with the ignition system in my 1990 model Isuzu Trooper with a GM 2.8L v6 265,000 miles.
On Christmas Day the the truck stopped firing while going down the road. I had a gut feeling that the ignition module had gone bad so I replaced it the next day and was back on the road again. At least for a couple or three weeks until I was going down the road about a half mile from my house when my Trooper instantly started running like crap. I knew that if I stopped the truck that it wouldn't start again. I was able to make it to the house. The truck would barely run, had no power and was backfiring. After it quit I could not get it started again. I figured it was the ignition module again, but I had it tested and it passed using two different analyzers. Then I figured that the timing chain had jumped time and when I tested the the play it had nearly 10deg of play, so I replaced the timing chain. After replacing the timing chain the Trooper would start and run for about 5 - 10 minutes and then start backfiring and wouldn't start until it cooled down. Tonight I went and had the ignition module tested again. This time it failed, so they replaced it. After installing the new module the engine ran fair. I let it idle for about 15 minutes and started down the street. Within a couple of blocks the engine stopped cold - now the third ignition module fried.
I am out of ideas here. Does anyone have any ideas as to why the ignition module keep burning up?
Any help is appreciated.
Thanks
Mack
Thanks
Mack
