LIM gasket
  • LIM gasket
    How do I know with out taking my intake off if my car has pushroad guides on the LIM gasket it is a 96 lumina w/3100 at advance autos web site they have both listed for my car any help would be great
    If it's a '96, then it SHOULD have pushrod guides and roller rockers. As I'm sure you noticed, the intake gaskets are different depending on which valvetrain style you have. HOWEVER...
    If you go with the FelPro "problem-saver" gaskets- and you should- then you'll have the same part number whether you have roller rockers or not. I THINK that part number is MS98004T- but you'll want to verify that. These are metal/rubber gaskets, vastly better than the cheap (and original) plastic ones.
      thanks that way I can get the parts before I tare it apart
      Matt
        Lotsa threads on this subject- do a search and some lookin' around.
        KEEP THEM PUSHRODS IN ORDER! YOU ARE DAMNING YOU ENGINE TO A SUDDEN DEATH IF YOU DO THIS LIM JOB AND GET AN INTAKE PUSHROD SWAPPED WITH AN EXHAUST ONE.
        Ok... calmed down. But seriously, that was for the good of your engine. We get posts here all the time where somebody has FUBARed their V6 'cause they got a pushrod out of place. Don't do it.
          he's not kidding...
          Brian
          3400 SFI V6, 4T60e
            I know that I need to keep pushrods in order i have done headgaskets on a few other vechicles
              LMAO i have seen it done. It sounds like a diesel when first startup happens and then a boom!!!
