f'ing dexcool....
  • #16
    Wow... you must REALLY like changing antifreeze. I change mine every three years or so... maybe if I'm working on it for some reason. Better too much than not enough though. I reckon.
    I like 'em french-fried p'taters.
    One of my biggest gripes with dexcool has always been the FACT that it made literally thousands of Cummins N14 head gaskets leak back in the late 90's. I'm told that the formula has been changes since then to take care of the problem... and to be fair, that stuff IS run in lots of over-tha-road trucks nowadays, and I haven't seen any problems from it in recent years.
    Just the same, I don't trust it. I'll stick with my green low silicate diesel engine antifreeze.
    • #17
      My Cascade secret is out darn it....
      Never add tap water to DEX never, I repeat Never ever ever even a little.
      As Soon as the Intrigue get close to flushing or whenever I can afford to do so I will go green.
      Ouch dex and green mixed....
      I am back
      Mechanical/Service Technican
      • #18
        My 94 3100 Beretta came with Green. Be-ware that soaps can attack some rubber (like hoses, o-rings) so wash/flush at your own risk.
        • #19
          Some army trucks I worked on had dexcool in them and they ate brass fittings like nothing. I'm happy with regular green.
          95 Z26 3400/OBDII/GETRAG
          • #20
            this the sludge you are referring to?
            Originally posted by tractorman View Post
            Since I don't feel like re-typing my rant, here's a copy/paste from my post over as chevytalk:
            Here's my experience with Dexcool: When I met my wife back in 2000, her '94 corsica had that sticky brown dexcool sludge in it. That stuff is damn near impossible to get rid of. I flushed the system, used a steam cleaner, used soap... tried damn near everything. I never got it all out- matter of fact, the car always tended to overheat in hot weather 'cause some cores in the radiator were stopped up with the sludge. Finally I took out the radiator, and sent it to the shop to be rodded out. Put it back together, filled it with green antifreeze, and it's been fine ever since- but to this day, years later, you can still see some brown sludge in the bottom of the tank....
            interesting, informative thread. thanks.
            pictured below is the underside of my Rodeo's 3.1L rocker cover after the IM went to crap. i've been lacking an explanation for why this kind of sludge formed. but after reading this thread... could it possibly be because the type coolant i had used?
            • #21
              That isn't from the type of coolant you used, that looks like you had coolant leaking into your oil.
              • #22
                yea, i knew that much.
                what i didn't know is if the sludge that resulted was because of dexcool coolant? or was the type coolant even a factor?
                thanks.
                • #23
                  While I rarely pass up an opportunity to publicly trash Dex-crap... that's not your culprit in this case. The mayonaise under your valve cover is due to coolant in the oil- plain and simple. Any type of coolant would've emulsified just the same- seen it dozens of times.
                  Now... as to exactly WHY those intake gaskets leaked in the first place... feel free to blame Dex-cool. Lots of folks do, and I HAVE seen dexcool make many a perfectly good gasket leak. Granted, the GM gaskets are a $hitty design, and often split down the seam, causing a leak... so they might leak green stuff just as readily. Thing is, if the intake gaskets leak (and they always do on these engines), and you run the engine low on coolant for a bit... the green stuff won't turn to sludge like Dexcrud will.
                  • #24
                    I used your cascade flush "secret" after I used the regular Prestone flush when I switched from DEX to the green. I flushed my system with a garden hose 'til the water was clear.
                    The next day, my '95 Monte had a good sized coolant leak dribbling from the engine compartment PS rear. My heart skipped a couple of beats as I thought it might be coming from the engine's rear head we had pulled. I had just got done doing a top end (intake gaskets, oil pump o-ring). Imagine how happy I was to find the leak source was from a badly rusted/pitted metal heater outlet tube? The flush had removed all of the rust and allowed it to leak. I was glad it happened before it got really cold in NE Ohio (like right now..Brrr).
                    Now I have peace of mind knowing the green stuff is not going to turn to
                    jelly
                    jogasz28
                    ______________
                    '68 RS Camaro,
                    Project '69 Camaro in the works
                    '95 Monte Carlo Z34 loaded,
                    '99 Monte Carlo LS
