well guys i got the car back together and the damn thing still rattles at idle with the clutch engaged with the car in neutral... well not to long ago i slung a belt and now i think the thrust bearing needs replaced and thats what causing the noise..... what do you think? can i buy just the thrust bearing... this rattle is so annoying. its got a slight knocking but once i give it alittle gas it stops.. if i disengage the clutch it stops most of the noise.. but not all of it... what do you all think? should i drop the oil pan and see if its bad?? it sounds like most of the knock is coming through tranny but i have already had that apart and theres nothing that would cause a rattle or noise..
knocking 3400
knocking 3400
Last edited by rickykline; 01-01-2007, 01:33 AM.1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..Tags: None
what year tranny do u have? the external slave 282's throwout bearing likes to rattle alot. mine does it all the time[SIGPIC]
12.268@117... 11's to come!
this sounds more like a rod knock then the standard 282 throwout bearing... im going to see in the morning if i can get the crank to move in and out and if i can im going to drop the pan... probably still will if it doesnt.. sounds engine based but im praying its just that ive destroyed that thrust washer and i can roll a new one in its place..1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
well turns out the torque wrench i used to tighten the flywheel wasnt very accurate.. and the flywheel had loosened ..... SON OF A BITCH... at least i didnt run it long after the knock started..lol1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
