We just picked up a 97 Olds Cutlass Supreme, the previous owner said it has a leaking headgasket because when the car idles you get the signature steam coming out of the tailpipe; and the car overheats after driving for less than 10 minutes. We got the car home and did a pressure test on the coolant.
It held pressure for awhile ~10 minutes, so I figured the problem hadn't reached the point where it leaked all the time. So we started the car for awhile hoping to aggrevate the leak. We pressure tested it again and after ~5 minutes the cooling system began losing pressure, just as I had expected. Anyway, I tore it down thinking it was the LIM gasket. I get there and find that the gaskets are new.
So I figured either they leaked after being replaced or it is in fact the headgasket. I'm probably going to put the manifold back on and do a compression test, but I do think the problem is the headgasket at this point. I'd like to be 100% though. One weird thing is that when I took the manifold off I found what looked like paper pulp in the two coolant passages on the side of the manifold near the powersteering pump.
I wasn't too sure if this was pieces of the gasket or just that the last guy left a shop towel in there? Stupid people I guess. After all this my question is what would be the best approach if I in fact do have to change the headgasket? There's a lot of stuff in the way and I figured I might get some advice. Should I drop the motor out, lean it forward? I'm not sure, any advice would be greatly appreciated. Thanks all!
Regards,
Tee
Regards,
Tee
