I put not roller tip, stock, rockers out of a 3100 at the junk yard and i put them on my 3.1. they do not work. i noticed immeditately that they open the valves really far and i figured that it would run weird.
3100 rockers on 3.1 not working need help big time
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mile
LOL????? I put 3100 stamped 1:6 rockers in my 3.1 heads and it worked juss fine as far as I can tell.. it seemed to give it more lope and Tq. but lashing them was a bitch, and i had to use the 3.1 pushrods kuss the 3100 ones were too short.. but ya.. no 5 cyl sound. all the pipes read 280-300 degrees C idoling.. so all they cyls are doing there job.. the rockers are a little noisy but they were always that way even with the stockers.. i blame that on the 262 camVIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
I found out that the reason was that I bent a valve. The rockers would have worked.
Did you say that you have to set the lashing? i thought that you just set the tourqe at 18 ftlbs.
1996 Beretta
3100 SFI TURBO
Originally posted by Jbrogan View PostI found out that the reason was that I bent a valve. The rockers would have worked.
