Starting Issue after complete car rebuild.
  • Starting Issue after complete car rebuild.
    Ok, I put my 94 Grand Prix back together, and I am having what I think is some kind of security problem. (note this car was completely torn apart and re assembled)
    When I turn the key on everything powers up. and the car will not crank. If I leave the key in the run position and jump the starter then it will start but dies only a second later. Is something shutting the injectors down?
    What I am getting at is there something that i need to do to "reset" some kind of security?
    1999 Grand Prix SE 3100
    1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
    1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
    Maybe?
      Thanks Brad, I will let you know in about 45 mins! LOL
      Passkey 2 relearn.
      1. First, insert the ignition key and
      turn the ignition switch to the
      “On” position (Do not start the
      engine). Leave the switch on for
      11 minutes. The security light
      may flash or be on steady during
      this 11 minute period. Make sure
      the light is no longer on or
      flashing before proceeding to #2 .
      2. Turn the ignition switch off for 30
      seconds.
      3. Turn the ignition switch to the
      “On” position (as in step #1) for
      11 minutes again.
      4. Turn the ignition switch off for
      another 30 seconds.
      5. Turn the ignition switch to the
      “On” position for 11 minutes a
      third time.
      6. Turn the ignition switch off for 30
      seconds one final time.
      7. Turn the ignition switch to the
      “On” position one final time and
      wait 30 seconds.
      8. Attempt to start the engine.
      If the engine starts and runs
      normally, the relearn is
      complete.
        That didnt work....
          Problem solved.
            And you aren't going to tell us the answer?
            Oh BTW, welcome back...
              It was my mistake, I used the wrong VAT module.
