L body computer definition files
  • L body computer definition files
    hey guys, can anyone help me find the correct definition files to comunicate with A 1988 BERETTA GT with the 2.8 V6? i need the file for use on TunerPro software. any help would be great!
    the ECM ID is $6D, and the ecm code is either 1227727 or 1227730. my car has speed density.
    6d.ecu is in the downloads section, or it was anyway. As for communicating with it, I can't help you. Do you have a digital dash?
      yeah i have the digital dash. i think i tried the 6D.ecu file, but i don't think that it's the correct file for TunerPro. tunerpro uses a different type of file, i could be wrong though.
        You can import .ecu files in tunerpro. If you didnt have the digital dash I would tell you to use the newer codes and swap your EGR type and speedo code on it. Won't work with your speedo though.
          i guess what i really need to know is what file do i use to connect through the ALDL port so i can Data Log.
            I don't have any ALDL files on this site nor do I know how to make them.
