i cant rememeber if it was this site or another but i searched here and couldnt find where to get polyurethane. has anyone here ever bought it and where did you get it from? and if so, how did it work?
homemade motor mounts
What's wrong with the stock setup? It's not like these V6's are motormount-eatin' torquemonster bigblocks.
I've never understood all the hype about polyurethane bushings anyway. When the radius arm bushings on my old ford truck went bad, I replaced them with polyurethan bushings. Since then they've squeaked and clunked when it's cold out.
with a j-body, the mounts suck. they were originaly designed to be used with the low power 1.8l ohv that made 85hp. when the motors got morw powerfull (1.8 &2.0l turbo) and heavy (v6) the mounts never got upgraded.
my car is very clunky (mounts are to soft to keep the motor mounts from bottoming out in itself) and very anoying. with urethane mounts, its a lot stiffer.
im currectly designing my own mounts. stay tuned.
well the heim joints still allow movement but they cut down a good bit and remember- this is the prototype, things will be different on the finale version
he also has intakes that are alot like some of the others on the market, as well as strut bars
tractorman: My stock v6 3100 has ripped the upper mount in half. Lower dog bone is trashed, and I'm sure my trans mount isn't in good shape either. I upgraded my uppermount to the 95+ style too, that helped a lot, but now it's about done too. Thinking once it goes, I'm going to get the advance auto parts solid rubber mount, and then get the rksport poly upper insert. If you add dogbone mounts to the radiator support, keep your other stock mounts. The L body radiator support is not a strong struture and will bend/move with the motor.
I've got poly on my swaybar and it doesn't squeak. I've never had poly squeak, but maybe I'm lucky?sigpicNew 2010 project (click image)
