It's really sounding like ECM. If you had bad injectors, you would never get a good run.
How can you check your timing???
I was just talking to 92turboLE on the W-body page and he had all the same symptems I have but it was his coolant temp sensor. This kinda makes sense since right before the problems started my fan would not turn on, so that is a cheap 36$ part that I will put in this weekend and depending on what the $ flow is likw I might try a IAC, EGR, and AIT sensors. If I replace the coolant temp sensor is there any thing else around there that I sould replace too?
Also try the ignition module...I've had the same symptoms, and it either was not grounded with dielectric grease(wears off after a few years) or the module was just bad and needed replaced. Auto Zone will test them for free, if you can get them off.(try and keep some skin on your knuckles)...also have a look-see at your coils while you're at it.Teal Indy
Yello Indy
90 STE
90 GTZ
90 EURO
