Stock heads are 28.2cc, stock 3100 piston is 28.6cc. Plugged these into a calcluator with a 1.5mm gasket thickness and it spit out 7.x:1 compression. So...um...wtf?
Anyone else measured a piston or head? Id like to compare but something really isn't adding up for me unless the piston sits higher than the block, which I can't check as I dont have an assembled block to look at.
Now we need a 3100 gasket bore diameter.
