Id like to hear some thoughts on this:
Its not viable for all areas and you need to upgrade the fuel system (at least pump and injectors)
Lets not talk about if this is actually worth it or not, lets talk about what would need to happen to make this possible on a 60v6 pushrod. Particulary a 3400
From my inital research it looks like the 22# injectors would need to be bumped up to 30# or so. A walboro 340 fuel pump should provide enough pumping power.
The big question behind this would be: Would a standard ODBII PCM tuned be enough to get things running right even though we lack wideband O2 sensors?
Any other thougths and ideas on the technical merits of this are certainly welcome.
