Pulled the o2 sensor this morning while waiting for a ride to work...It came out easily, thank goodness. Still won't start, so I don't think I melted the cat, but it might still be flooded from yesterday, so tonight I will pull the plugs and run a compression check (pressurizing the cylinders seems to vaporize ?? the excess fuel and help dry them out - it comes out of the release valve on my compression tester).
Even if it was flooded, with the o2 sensor removed, would I be able to feel vacuum while cranking (with my thumb over a vacuum line)? I got nothing...weird.
I am also going to try a new ignition module and pickup coil since the spark wasn't blue.
Thanks for everyone's help so far.
