does anyone here know for 100% certainty weather the GEN-II pushrod 660 IS or IS NOT an interferance motor? someone here has to know for sure lol.
apparantly my timing chain and/or camshaft broke on my turbocharged VIN 'T' '91 3.1 MPFI engine. while i was revving it to ~5000 RPM Neutral (i just installed the turbo and was checking things). it sounded great but the engine just completely died and wouldn't start back up. no bad noises or anything it just died. i found out later after pulling the front valve cover that the valvetrain was not moving while cranking the engine (still no bad noises while cranking the engine....the starter just sounded like it had less load on it).
also - the engine has 227,000 miles...is the problem more than likely a broken camshaft or the timing chain?
thanks in advance for any help!
