Will all of the oil pans interchange between the rear drive 2.8 3.1 and 3.4? I am putting a 95 3.4 into a Geo Tracker and the drain plug is on the passenger side, it ends up tight and directly over the front diff during my test fit. I see oil pans available with the drain plug on the drivers side listed for older S10 and Camaro 2.8 and 3.1. They sure would make it a light nicer when time comes to change the oil. Will one of those oil pans bolt up and work on my 3.4 OK? Anyone know if they are shallower, deeper or the same depth as the one I have off of the 3.4? It measures 8" deep at the sump with the drain plug in it. Its a tight fit.
Thanks,
Roy
Thanks,
Roy
