Changing Injectors from SFI to MPFI
  • #16
    Older 3100s also use the 2 seperate sensors. Mine does, and I know Korbendallas's 95 did as well, cause he mentions it in his swap guide.
    • #17
      yeah the 94-95 engines still used the sensor in the head.
      Colin
      • #18
        So, if I splice the green sensor wire into the yellow CTS wire, does anyone know if it will throw a code to the ECM?
        89 Z-24 Convertible - 3400 MPFI
        63 Chevrolet C-10 Pickup - 283ci
        01 Chevrolet Tahoe Z71 - 5.3L
        • #19
          it shouldnt throw any codes. and should work. i'd assume that the two sensors use the same temp vs. resistance values to provide the right info for the cluster to read right.
          Colin
          • #20
            Originally posted by v6h.o.
            GM also used on the 3X00's a 3 wire sensor that can be used to work for both functions of ECM and Cluster info.
            I found the part number for this if anyone else is looking to do this mod.
            Delco # 213-815
            I also have another question...I just got, off of eBay, a set of 3100 injectors from a 97 Lumina. Can I use those injectors with the 3400 fuel rail, or do I have to replace the fuel rail as well?
