Older 3100s also use the 2 seperate sensors. Mine does, and I know Korbendallas's 95 did as well, cause he mentions it in his swap guide.
Changing Injectors from SFI to MPFI
it shouldnt throw any codes. and should work. i'd assume that the two sensors use the same temp vs. resistance values to provide the right info for the cluster to read right.Colin
Originally posted by v6h.o.GM also used on the 3X00's a 3 wire sensor that can be used to work for both functions of ECM and Cluster info.
Delco # 213-815
I also have another question...I just got, off of eBay, a set of 3100 injectors from a 97 Lumina. Can I use those injectors with the 3400 fuel rail, or do I have to replace the fuel rail as well?89 Z-24 Convertible - 3400 MPFI
63 Chevrolet C-10 Pickup - 283ci
01 Chevrolet Tahoe Z71 - 5.3L
