how to tell differance between 2.8 and 3.1
  • #16
    ...and didn't the AWD Pontiac 6k come out in '89? It had the 3.1 all along.
    60v6's original Jon M.
    • #17
      AWD pontiac 6000?
      I Like V660s
      Does Chevy make beer
      ~Jayme~
      • #18
        Originally posted by TheProfessor
        AWD pontiac 6000?
        Yeah, where have you been? If I still had my old Favorites list, I post a couple links.
        I believe the AWD 6000 was introduced in '87 though, and used a 2.8 (obvioulsy) for the first few years, the in '89 the 3.1 was "tested" in the 6000 and Grand Prix chassis'.
        • #19
          i was swaping the crank sensor out on this beast yesterday and i looked up in the general area of the crank and rear knock sensor and i saw a big "T" cast into the side of the block.
          does that mean anything??
          could somwone with a "real" 2.8 look for me?
          -Chris
          1992 Chevrolet Lumina Z34 3.4L TDC Getrag 284
          1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
          1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
          1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
          • #20
            Thats the "T" you are looking for.
            • #21
              does that mean the 2.8 'W' engines have a 'W' cast into the block? and is there really any difference between 2.8 & 3.1 blocks anyway?
              fwiw, my 3.1 'V' TGP engine and my '91 3.1 'T' engine both have that big 'T' cast into the side of the block.
              '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
              '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
              GM W-body Forums
              • #22
                ill check my block tonight. i have a gen 1 and 2 2.8l block sitting here
                • #23
                  I thought the '88 Pontiac 6000 AWD got the 3.1??
                  Brian
                  3400 SFI V6, 4T60e
                  • #24
                    so any update on the letter cast into the block?
                    -Chris
                    • #25
                      I believe, the 3.1 was available in only Pontiacs in '89. All cars in '90. If it helps any, I once had a '93 Lumina with a 2.8
                      \'71 Cutlass S 5.8
                      \'84 Delta 88 3.8
