i think we all know these first few specs, im just going to post them anyways, but there have been changes internally to crank/ conrod, and piston pin specs. here's what i found checking out our online service manuals:
Displacement
3.5L
214 cu in
RPO
LX9
VIN
8
Bore
94 mm
3.70 in
Stroke
84 mm
3.31 in
Compression Ratio
9.8:1
cams are the same lift:
Camshaft Lobe Lift - Exhaust
0.2727 in
Camshaft Lobe Lift - Intake
0.2727 in
Connecting Rod Bore Diameter
60.322-60.338 mm
2.375-2.376 in ( up from 53.962-53.978 mm /2.124-2.125 old spec)
Connecting Rod Length - Center to Center
150 mm
5.9 in (old spec 5.7inch)
5.9 INCH RODS! thats a 1.78 ROD STROKE Ratio!
up from the 5.7inch 1.72 rod/stroke ratio. not much of change but still better ratio than before.
Piston Pin Bore Diameter
24.008-24.013 mm 0.9452-0.9454 in
(old spec 23.005-23.010 mm / 0.9057-0.9059 in)
Piston Pin Diameter
23.997-24.000 mm 0.9447-0.9448 in (same pin diameter as the New LS_ GENIII small block engines)
(old spec 22.994-22.997 mm / 0.9053-0.9054 in)
just thought i'd post this for those inquiring minds. as i know a few of us are watching this engine with feavered antisipation to get our hands on one for a base to start an all out high performance build from. (i know i am)
Displacement
3.5L
214 cu in
RPO
LX9
VIN
8
Bore
94 mm
3.70 in
Stroke
84 mm
3.31 in
Compression Ratio
9.8:1
0.2727 in
0.2727 in
60.322-60.338 mm
150 mm
Piston Pin Diameter
