wtf no oil pressure
  • wtf no oil pressure
    hey guys
    my mechanic finished the rebuild on my 3.1
    he primed it and was breaking in the cam
    the oil pressure was up where it should be for about 5 minutes
    and then dropped like a stone
    anyone have any idea what the hell could have happened
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    Did you use a new oil pump? It's a good idea, I have seen a few of those oil pumps fail.
      i have a melling hv pump and its like brand new
      I Like V660s
      ~Jayme~
        Check it with a manual gauge... The sending unit failed on my S-10 with a 4.3 within a week of putting in a new long block. I think maybe the higher pressure from the fresh motor caused it to fail. Who knows
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
          im pretty sure he used a manual gauge
          I Like V660s
          ~Jayme~
            Make sure no oil galley plugs have come out. If any did there would be a lot of oil around. Also you may need to drop the pan and make sure the pickup is not touching the bottom, that it is not clogged and that it has not come off the pump body.
              Pan's gonna have to come off so you can check it.
              I modify stuff
