Upon investigation, the camshaft used in all 1999 and older La1 variants seems to be the same(using part numbers). So the power difference between the alero engine and the minivan variant must be something else. 15hp and 10 ftlb is too much of a difference to be different prom tuning, oem is too conservative. If it were a higher compression ratio being used then the power bump would have more torque increase and peak power would stay around the same rpm, not increase peak power up 500 rpm from 4700 to 5200. Its not the cam, so it must be higher ratio rocker arms then right? to simulate a bigger cam. It has to be. If so then this would be a good cheap mod for non minivan la1 variants. Searching did not help, someone smarter then i chime in!
La1 variants rocker arm differences?
Exhaust... the U vans didn't have stupid exhaust routing like the N and W bodies. There is no appreciable difference in any part of the actual engine. The GAGT and W-body cars got higher numbers due to a less restrictive dual exhaust muffler and the vans got higher numbers yet due to much simpler exhaust routing...sigpic
- Ben
If you are looking for extra power the easiest is a tune and exhaust1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
