crank position sensors - 1991 vs 2000
  • crank position sensors - 1991 vs 2000
    i swapped the '00 3400 in place of my 91 dohc. i just thought of something. are the crank sensors that go into the back of the block between the head and the trans the same/ i'm not sure if i changed it out. they looked the same and used the same plug and same color wires to the ignition module, but i cant find a listing on any parts store sites for the '00 sensor to compare the part numbers
    They are both the same according to AC Delco. Both are PN 213-148.
      gracias amigo.
      i was checking before i put the downpipe on.
