Hello. I'm need to pick up a helicoil tomorrow for a stripped M10 rocker arm bolt hole in an old head I want to reuse and I don't know what pitch to get. I read M10x1.25 in one post. Then another post of someone using an M10x1.5 heli-coil. Then a google search found me one person who said it was M10x1.0. Does anyone happen to know off hand the actual thread pitch?
M10 Rocker Arm Thread Pitch?
I'm going to go out on a limb here and say its M10x1.5 and I'm using TimeSert's website as a guide. This is where I got my M8 kit from. Their M10 says 1.5 pitch
Last kit at the bottom
cadillac northstar head gasket repair, cadillac northstar head gasket repair, stripped thread, stripped out theads, helicoils, ford sparkplug repair, repair ford sparkplugs blew out with time-sert, thread repair problems, spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threads got stipped out of ford sparkplug, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts for striped out threads, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
Thanks. You were right. M10x1.5 it was. I went to the local autoparts store and sized it up, but damn these Aluminum heads. The Heli-coil went perfect on the first motor. Went in better then new. The second head was almost disastrous. Eventually I got so angry i ended up snapping the rocker bolt in the heli-coil and it wouldn't come out no matter what. Long story short I drilled down the middle of the M10 stuck in there, threaded it for an M8x1.25 rocker I had laying around, and everything went smoothly from there.
