I have a 195* thermostat in my 1996 Monte Carlo (3.1)
When warming up I can watch the temp needle rise up to 195 and then the thermostat will open and it goes down,it then goes up again and is then fully warmed up.
The problem is once mine warms up it only runs about 180-185 unless I am at a stop and in gear.
I have had it hooked up to my Autoenginuity Laptop and it shows this(I wanted to check my gauge accuracy)
Car runs beautiful but gas mileage is only about 24mpg combined when I used to get 29.
Would that small temp difference affect mileage that much and why would it run a tad cooler most of the time?
The Thermostat is opening at exactly the right temperature, pre O2 sensor is a Bosch and is only about 6 months old.
LTFT are going to negative 6 and 10%
Engine Vacuum is a steady 18" and correct.
