Hello, I am making the PCM harness from a 3100 out of a 98 malibu into a swap harness, and I have a PCM connector pinout. When going through each pin I noticed the oil pressure sending unit sends a signal to the PCM but has no direct output. Is this fed through the Serial II Data port to the idiot light on the instrument cluster or does the PCM need this signal for some function? Thanks.
PCM need oil pressure output?
Originally posted by The_Raven View PostIt's simply used by the PCM to measure the fuel pump voltage.
Originally posted by 1988GTU View PostIt should extend the cranking before it fires and starts up with no OPSU connected/broke/hodgepodged'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
