Hey all,
This is a long one - Here's the back story scroll down for the point.
I had a shop do some work on my '95 Firebird about 18 months ago, they fixed a bunch of oil leaks (RMS, valve cover, etc), valve job, new steering rack and pump and a few other odds and ends. I drove the car for 3 months and it had a rough idle that got worse when it was hot and humid or raining out. I thought it was electrical, but the shop had replaced the plugs and wires with OE replacements. I replaced the coil pack think that it may be a failing coil pack - no joy. So I replaced the injectors - still no improvement. After the 3 months, I bought my truck and stopped driving the Firebird for a while. The car sat for a month and when i went to drive it it was very hard to start and very rough running for a minute or so, then back to its standard rough idle.
The Point
Fast forward 4 months - the car sat again but for 4 months, I ordered a set of 8.5mm MSD plug wires, put them on, tried to start the motor and it wouldn't crank. Charged the battery - still wouldn't crank. Pulled the plugs, 3 of them were rusted, spun the motor over and it shot coolant everywhere.
Fast forward a year and I brought the car back in to the shop after a years worth of back and forth with the shop owner and they disassembled the top end and we can't for the life of us figure out where the water came from. See pics below:
![Click image for larger version
All of the gaskets and gasket surfaces are clean, but the cylinders 3,4, and 5 filled with water. There's even a waterline in the intake manifold. Thoughts anyone?
Thanks,
Brian
The Point
Thanks,
Brian
