Rear cam plug
  • #16
    Don't know why it would not work with a stock cam. Larry
    • #17
      Stock cam is not flat at the end of the bearing journal, it has the hollow core tube sticking out of it. I'll take a picture tomorrow AM on why.
      • #18
        I have one here, it will fit if you just knock the plug in the minimum amount to get it flush with the bore. If you need more clearance I guess you could take a hammer to the center before you drive it in. The Dorman plug is very thin to start with. Larry
