i am curious if anyone knows the compression height of the 3.6 piston.
bore between the 3500 and 3.6 are the same, and so are rod length. however, the 3.6 has a slightly longer stroke of 3.37 vs 3.31 of the 3500 according to the gm spec sheet.
all things being equal the 3.6 piston would sit higher in the bore unless the compression height was changed.
i think people here can figure out why. search didnt turn up the compression height.
